Shadetree Welder
发表于 2021-9-1 01:02:48 | 显示全部楼层 |阅读模式
Looks like we have a Celebrity in our midst.I just got my new "Practical welding Today" magazine. Lo and behold there was a story on Shadtree Welding services of Custer Park Il.Congradulations Ron
Reply:Shadetree ill be expecting an autographno you cant fix it with a hot pass.BORN TO LOSE, LIVE TO WIN.
Reply:Well Jim quit sittin there, have Dogzilla show you how to scan and post it.Appreciation Gains You Recognition-
Reply:Here it is (I hope) Attached Filespratical weld_h.htm (399 Bytes, 172 views)
Reply:Someone let me know if the above worked
Reply:Didn't work. But I have to type more words.
Reply:Nope.  It went somewhere, Jim but just a blank page.
Reply:I'm lost! One of you computer whize's please help me
Reply:Where is the article?  On a website or on your hard drive?
Reply:Awww shucks, now I am embarrased.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:Well Shade at least you have maintained your humility- we like our heros humble. "All that is required for evil to triumph is that good men do nothing"
Reply:Cutter:I scanned it , and saved it as an "HTML", cause that's what the download thing said the webb sight would accept.I also have it as a "Word document"
Reply:Okay Jim,I consulted with my online advisor about it.  She says if you have it as a Word document then you can open it, copy & paste it in just like a regular post.  Of course, you may have to post it in several pieces because of the character limit.  So maybe try it one page at a time.
Reply:I can't to highlite the text??. Maybe I'll try to post it as a picture.
Reply:Jim, can't you just hold down your left button and drag your cursor to highlite it?  Or try right clicking & click "select all", right click again & select "copy"?  Then paste it in and proof it, deleting anything that shouldn't be there before submitting.  I know that may sound easier than it is but any other way of doing this is probably gonna have a learning curve.
Reply:he scanned it in Cutter, it's an image so he can't hilight anything.what he needs to do is attach it like he would an image, Jim you might have to convert it to an image format usable by the board if it's not already.
Reply:Hmmm, I thought you could copy a Word document?
Reply:Try to highlight the text and hit Ctrl-C (nothing visible will happen).  Then come to the text box where you're typing in your post here, and hit Ctrl-V.  This is how you can cut and paste from any one application to any other.  I don't think it will properly display pictures, only the text portions.Proud to be a UNION worker.  Better pay, better benefits, better work environment.  UA Unions = working for the working class!!
Reply:Jim; It will be easier to tell you where to look for help than explain it-if I could. Try this. Click on "Help" at the top of your home page and search for "HTML". The program will show instructions about photos, etc. and how to make them work.Even better, I think. Re-scan the article and save it as a JPG file. I think your scanner should have that option. Do you have a photo editor software program? Your scanner should have several file formats. If it doesn't have JPG, it should have one that the photo editor will accept and then you can size it to work on this site and save it as a JPG.
Reply:Jim; This is a test.  If it works, open the HTML file and copy it, select all-copy, and open WORD and paste it. Save as a Word document and then insert it in your reply. Attached Filessenior member.doc (56.0 KB, 91 views)
Reply:Well, it worked for me.  I copied the top two posts on this page as a HTML file to my computer. Then copied it and pasted it to Word, saved it and then copied it to this site.
Reply:If the article was saved as an image in a word document you might be able to attach the whole document to the post.  If you have OCR software and it is saved as text, you could copy and paste the text.  You might need to scan the file again and save it as a .jpg file, then you could attach it directly to the post.
Reply:Maybe Franz can cook up a secret recipe for this as apparently it's going to take longer to see this pic than for cutter to get that vise working
GMT+8, 2025-12-19 23:34 , Processed in 0.101406 second(s), 18 queries .
