metal velcro
发表于 2021-9-1 01:02:48 | 显示全部楼层 |阅读模式
Thought you guys might find this interesting. Click on the link below.Metal Velcro axehind
Reply:That was fascinating.  I wonder which products it'll be used on first?I mean, after they use it to make bombs, of course.........
Reply:I doubt the adhesive manufacturers and too excited about this discovery.   I'm not sure, but I bet it will be a pain to repair anything with those little hooks on it.  As it stands now, you have to scrub the hell out of something that has glue on it.  Now you will have to grind whatever is stuck to the metal to get it off.Common sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-20 00:01 , Processed in 0.094223 second(s), 18 queries .
