Welding Anneled 4130 Steel
发表于 2021-9-1 01:02:46 | 显示全部楼层 |阅读模式
Can it be done?? is there anny specail procedure to follow??
Reply:is it 4130 to 4130?, i'm not an expert by any means, but steel is easy to work with, i say your chances are goodStangnetShop Full Of Stuff. Joey
Reply:It will be to mild steel...3"  .313" wall 4130 steel tube i  plan on useing it to replace the stock axle tube on my toyota axles...
GMT+8, 2025-12-19 23:58 , Processed in 0.106137 second(s), 18 queries .
