innersheild
发表于 2021-9-1 01:02:42 | 显示全部楼层 |阅读模式
having troble with porosity and what looke like worm trails??? any suggestions
Reply:I think crank the V down or the wire up.  Crank the wire speed up,,, heck, its getting tought to remember this stuff anymore, been a long time since I run one.Last edited by Sberry; 07-30-2004 at 11:33 PM.www.urkafarms.com
Reply:The worm tracks can be caused by traveling too fast or using too low gas flow.  Basically, your gas flow isn't shielding the weld as long as it should.  I know it sounds a bit odd, but try it.  Either slow down or turn the gas up and see if that fixes it.
GMT+8, 2025-12-20 00:19 , Processed in 0.090965 second(s), 18 queries .
