Testing Auto Dark Hood?
发表于 2021-9-1 01:02:40 | 显示全部楼层 |阅读模式
IS THERE ANY WAY TO TEST AN AUTO DARK HELMET?I DID A DECENT BIT OF WELDING YESTERDAY AND NOW TODAYIM FEELING IT.  MY EYES ARE A LITTLE SORE, AND WHILE WELDING IT SEEMED LIKE IT WAS FLASHING ME JUST A TINY BIT EACH TIME.ITS A MILLER HOOD AROUND $260 AND ITS ABOUT 2 YRS OLD, THEY CLAIM 5 YR WARRANTY, AND ITS THE AUTO CHARGE TYPE, I DONT THINK THERE ARE ANY BATTERIES?THANKS
Reply:You may try adjusting shade and mine has  a delay adjustment, if yours does you may need to adjust it as well.EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:There was an article that I read on http://www.millermotorsports.com/mboard/ where a guy used an expencive photo light meter to compair hoods.  You can make your own pretty easy with a volt meter and a small solar pannel.  Just compare your hood under light and a regular one with a 10 or 11 shade lens and compairthe two readings.Common sense in an uncommon degree is what the world calls wisdom.
Reply:THATS INTERESTINGWITH THE SOLAR PANEL.AS FAR AS ADJUSTING IT I'VE ALREADY GOT IT AT 12.5 SHADE, A VERY LONG DELAY, AND MAX SENSITIVITY
Reply:Toyota,Try shortening delay. Also, shade setting depends machine settings. all processes. The user manual for the hood will get you in the ball park. Fine tune from there. Hope this helps.moe1942
GMT+8, 2025-12-20 00:01 , Processed in 0.069901 second(s), 18 queries .
