used stick welder ??
发表于 2021-9-1 01:02:40 | 显示全部楼层 |阅读模式
AC/DC 225/125 AC/DC Stick WelderList Price:521.00 (USD)K1297 AC/DC 225/125 230/1/60Is this a good welder?? I got this with a bunch of rods, helmet, and two 50’ extension cords for it. Torch setup with two tanks of oxy and sedalin( check spelling) with assorted heads and a cart and he also threw in a portable torch setup. Same as above but with smaller tanks. For $100.00
Reply:was this a good deal??
Reply:I have one,, its a Lincoln correct? It is an extremely good machine and certainly would have bought another for 100$. It has a great arc, nearly as good as any I have used.  I think you robbed the guy.www.urkafarms.com
Reply:I've had one for 25 years.  They are very versatile and a great buy for the money.Get it hot and hit it hard...
Reply:It is a lincoln. I started laying down some beads last night man its sure is differant then my little wire feed welder. I also cut some 1/4 thick square tubing with the OA torch, cut through it like butter.  Tonight I'm going to try welding the two pcs back together.  We'll see how that goes
GMT+8, 2025-12-20 00:01 , Processed in 0.134789 second(s), 18 queries .
