newbie advice
发表于 2021-9-1 01:02:39 | 显示全部楼层 |阅读模式
: i would like to post my 2 cents advice to help the up and coming rod burners. i would say that you need to spend equal time practicing layout and torch work as trying for the perfect bead. a good welder is only as good as the things he can build (especially for millwrights ,oilfield and rigging ) .i found that better beads come easer when every thing fits properly.     well theres mine.
Reply:Clean metal and good fit make it a lot easier.
GMT+8, 2025-12-20 00:00 , Processed in 0.122281 second(s), 19 queries .
