Does Sheilding Gas Cool sheetmetal?
发表于 2021-9-1 01:02:36 | 显示全部楼层 |阅读模式
I thought of this today, as I was looking into regulators and bottles to add to my little lincoln pak 15. I am still trying to nail down good technique for welding sheetmetal (autobody), and I've had some melt through problems. I was curious as to whether running gas as opposed to flux core might help this, as the sheilding gas might carry away some of the heat. Thoughts?
Reply:Gas shielding will make sheetmetal way easier, Talk with your gas supplier and let him know what gauge you are working with, He can get the best mix for you that wayStangnetShop Full Of Stuff. Joey
Reply:Do you have a WeldPac 115?  If so, I don't thik it converts to GMAW.  It only runs flux-core, I think?  If you can convert it, the gas doesn't cool the weld metal, but the gas properties affect the weld penetration, the amount of spatter, and the weld appearance.  You will most likely wind up using C-25 (75% Argon/25% CO2).Hank
GMT+8, 2025-12-19 23:59 , Processed in 0.103540 second(s), 18 queries .
