would twin tungsten instead of twin carbon work?
发表于 2021-9-1 01:02:35 | 显示全部楼层 |阅读模式
Could you maintain an arc between two tungsten electrodes (3/16" diameter) like the twin carbon process? The little testing I have done resulted in the electrodes burning off much faster than I would like. I was using 3/16" thoriated because that was the only type I could find. I have heard that others have easier striking and last longer. There will be a 1/16" wire being fed into the arc. So far it has also acted as a starter for the arc as well.It is a long story as to why I am trying to get this to work but any advice would help. I made some water cooled collets and that helped. Also it seems as though my best bet will be AC current but I have only ran it from my big DC box as of yet. I figured before I get back to trying I would post this and see what kind of ideas I can get from you guys. AC or DC, sharpened or balled electrodes? Etc. Anything you have seen or done like this before?
GMT+8, 2025-12-19 23:59 , Processed in 0.065332 second(s), 18 queries .
