Looking for a Rosebud??
发表于 2021-9-1 01:02:35 | 显示全部楼层 |阅读模式
Hi ti the Forum from a newbie in NW WASHINGTON state - I have a light to medium duty Victor J100 Oxy/Acetylene set and am looking for a Rosebud tip to fit it or if someone could suggest an idea for building one?? Thanks
Reply:try epay for used  or look up  victor on the web and find the nearest local  dealer /repair depot.  tips provide the mixing of the fuel and oxygen as well as distribution to the ports so it would probably cost more to make than buy  plus you risk a flashbackif your design is incorrect.Terry
Reply:Also, what size bottles are you using, a small gas bottle has problems running these big tips.www.urkafarms.com
GMT+8, 2025-12-20 00:03 , Processed in 0.039720 second(s), 17 queries .
