new welder,hook up to generator?
发表于 2021-9-1 01:02:33 | 显示全部楼层 |阅读模式
hi, i just bought a new welder off e-bay. it's about a 200 amp. and didn't come with a plug. went down to the local hardware store, and was tryin to think of the best plug outfit for it. it can either be 110 or 240. I may be a wiz at lawncare, but electricity isn't one of my strongest points. i got to in hope i could have it portable for field work, wanted to use my 5000 watt generator to power it. this evening i hooked up the ac arc welder by using a 20 amp, 250v plug and hooked into the 240 side of the 5000 watt generator. alli was getting was chicken scratch and nothing much more. called it a night after 10 minutes of that. what amperage of plug should i use?  is a 5000 watt generator powerful enough to do the job?  any help would really be appreciative..
Reply:Do you have a make and model for this machine?  What type is it, stick or mig? There should be a diagram in the OM for it.www.urkafarms.com
Reply:I run my mig off a 6.5K generator. In fact its all on wheels and my welder is on the same kart so I can wheel it where I need it.Bill W aka AntmanUp on the Mogollon Rim in Arizona. God and 4 Wheelers Country!
Reply:If it's and 'either' / 'or' type machine it is vry likely there are straps inside that need changed for conversion back and forth. More than just what plug you put on it or what you plug it into."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Yes, I would suggest you check out the Manual for changing from 115v to 220v. I would also think you'd need to do more than change just the plug.Bill W aka AntmanUp on the Mogollon Rim in Arizona. God and 4 Wheelers Country!
GMT+8, 2025-12-20 00:02 , Processed in 0.161774 second(s), 18 queries .
