Types of steel
发表于 2021-9-1 01:02:30 | 显示全部楼层 |阅读模式
Dumb question...Is there a steel square tube product that doesn't have the rolled outer edges?  I'm guesing that is what hot "rolled" means, that the edges are actually bent around a square form.  What I'm looking for is what aluminum square tube is shaped like, 90 degree outer edges.Thanks!--Evan
Reply:Ive never given it any thought,but now that you bring it up.i have never seen steel tube that didnt have the rounded edge.
Reply:I have seen square tube in aluminum (with square edges), some commercial buildings use this for gutter or roof drain spouts.
Reply:No, that is not what hot roll means. Hot roll is the process by which it is made.www.urkafarms.com
Reply:You MAY be able to find it as an archatectural shape in steel. It isn't common because it is a pain to make. Because Aluminum is soft and has a low melt point, Aluminum shapes are generally extruded rather than rolled (think play-doh fun factory). This is cheap and gives a lot of flexibility in profiles.For practical purposes, steel can't be extruded. Steel is generally rolled, and for tubular products, a sharp corner requires a great deal of plastic action at the corner (the 'thickness' is very much greater there). Steel doesn't like this, and the process gets more expensive.
Reply:ahh I see thanks for the info. thought I would just throw the question out there --Evan
GMT+8, 2025-12-20 00:29 , Processed in 0.164633 second(s), 18 queries .
