TIG torch part needed
发表于 2021-9-1 01:02:29 | 显示全部楼层 |阅读模式
Where can I get the plastic peice that goes on the back of the TIG torch?  Mine fell of the welding table and broke. I have a Miller Diamond Back torch.Millermatic 175Miller Sychrowave 180sd
Reply:what you are looking for is called the back cap, here is one for a weldcraft type torch http://store.weldingdepot.com/cgi/we...ml?id=GBtXDes4  you should be able to drop by airgas with the torch model number and get the part right quickStangnetShop Full Of Stuff. Joey
Reply:I get most of my stuff from www.aglevtech.net , he has all those backcaps and lots of other accessories, he also has an ebay store, sometimes the stuff is a few bucks cheaper at his ebay store.Jimwww.jmfabrications.comLincoln Precision TIG 375Lincoln Precision TIG 275Lincoln Power MIG 255Lincoln Power MIG 140CMiller Dynasty 350 (x2)TD Cutmaster 80
Reply:Good sight .  Thanks.Millermatic 175Miller Sychrowave 180sd
GMT+8, 2025-12-20 00:32 , Processed in 0.039402 second(s), 17 queries .
