Need input on tubing bender purchase
发表于 2021-9-1 01:02:24 | 显示全部楼层 |阅读模式
I want to purchase a tubing bender for bending aluminum round tubing. I'm looking at Pro-tool, jd2 and hossfeld. I am not sure that I could make the same bend twice with a Hossfeld since I never used anything but a small hand bender before. The jd2 has a really positive website with all the info and specs but the Pro-tool seems to look more robust and the dies are cheaper. Does anyone have any positive or negative feedback about either? Thanks.
Reply:I've got the JD2 and I don't have anything bad to say about it!  Mine is the full manual version, and I use it to bend up roll-bars and cages for drag cars.  I have two sets of dies, 1-5/8 and 1-1/8.  I love it.  I just wish I had more time to use it!!I got mine from Van Sant, and don't have any regrets.Later,Maxx Levell Racing...There Can Be Only One.
Reply:I have the jd2 that I purchased from Van Sant and use it to bend aluminum tubing. I went with Van Sant becuase they have the dies that go 180 degrees. Pro tools has these dies but they are treated more like a special construction request (more money?). The jd2 will bend identical bends consistently and bending 180 degrees helps when I am building bicycle forks.TiggerAaronHTP Invertig 201w/ CK-20 torch and Bernard ChillerHTP MicroCut 300 plasma cutterLincoln R3S-325 w/ TA 17A Wire FeederVictor Super Range II O/A kitClausing/Colchester 13X40 LatheBridgeport 9X42 Mill
Reply:Thanks very much for the info. I had hoped to get some opinions on the Pro-tool. I watched the videos and the pro-tool seemed to have more travel on the handle for the degree of bend than the  jd2. I guess this extra leverage would be better on the larger tubing. I tried to contact Pro-Tool today for the full die prices but they were closed for the holiday. I have a question forTigger Aaron. Do the dies scratch the aluminum?Thanks again,Holden
Reply:Yes the dies do scratch the aluminum. I usually sand and buff out the scratches. If you don't want to go that route, JD2 does have special die follower inserts that are made of delrin that won't scratch aluminum or stainless, it is more $$ though.TiggerAaronHTP Invertig 201w/ CK-20 torch and Bernard ChillerHTP MicroCut 300 plasma cutterLincoln R3S-325 w/ TA 17A Wire FeederVictor Super Range II O/A kitClausing/Colchester 13X40 LatheBridgeport 9X42 Mill
Reply:I have the Pro Tools 105 HD, very nice, no complaints about it at all!www.jmfabrications.comLincoln Precision TIG 375Lincoln Precision TIG 275Lincoln Power MIG 255Lincoln Power MIG 140CMiller Dynasty 350 (x2)TD Cutmaster 80
Reply:Thanks everyone for the info. I chose the jd2. Just bent the first piece of alum. today and I like the results. I plan to build boat items from aluminum. I also just purchased a Miller Sincrowave 180 tig welder. I am sure I will have lots of questions for everyone before I get satisfactory results. Thanks in advance.
GMT+8, 2025-12-20 00:31 , Processed in 0.155851 second(s), 18 queries .
