Fixing a Counter top.
发表于 2021-9-1 01:02:23 | 显示全部楼层 |阅读模式
I have a laminate counter top, that has lifted.   I'm not sure why the outfit that built this kitchen had to put the seam right beside the sink.  There's alway's water sitting on the counter near the sink.   I have re-glued the laminate down, but I have a slight gap between the two pieces.  The laminate is a black marble pattern.           Does anyone know what I could use to fill this gap, to help keep the water from seeping under the laminate again?     I know this is a welding site, and I know if it was a metal counter top. a Mig would have this fixed in short order.  I also know from the previous post on MDF, that others on this site are woodworkers too.  Do any of you do any cabinet work?
Reply:Hey, Theres no problem with posting about woodwork, it's just as important as metal anyday.  Have you tried an epoxy adhesive on the laminate?. You could try a dark wood filler or even body filler (bondo) with a black dry pigment mixed in. It wouldn't take much of eitherStangnetShop Full Of Stuff. Joey
Reply:OK, I'll give the bondo a try, Is it waterproof?  I've never used the stuff.Lincoln 225 AC/DC, Hobart 140 Mig. Oxy/propane Victor torch.(2) Makita 5" angle grinders  one with zip disk, 14" chop saw.  and just about every other tool you can think of. Whoever has the most toys when he die's ..... Wins!
Reply:pretty much when sanded with a fine grit paper. It's a plastic resin. You could use a little clear lacquer or enamel on top for extra added protection.StangnetShop Full Of Stuff. Joey
Reply:You might also try underwater repair epoxy. Doesn't lose the bond when wet (bondo will, slowly, release if water gets under it)  Chesterton, Devcon, and all of the other major specialty adhesive manufacturers make the stuff. Usually  gray, but paintable to match.I Might also lay atainless trim banding over the gap, and alother piece on the other side of the sink to match, to hide the repair and provide additional mechanical protection.
GMT+8, 2025-12-20 00:30 , Processed in 0.088237 second(s), 18 queries .
