which to buy?
发表于 2021-9-1 01:02:21 | 显示全部楼层 |阅读模式
As I posted before I want to get into welding, starting off in the garage and then taking classes and getting a good set-up in time. Money is tight so I can't justify alot of it right now. I found these two at Sears, Which is better?Lincoln Electric- K1790-1 /  Clarke- weg490There is only ten dollars difference in the two.
GMT+8, 2025-12-20 00:29 , Processed in 0.093786 second(s), 18 queries .
