Argon / CO2 refill
发表于 2021-9-1 01:02:20 | 显示全部楼层 |阅读模式
I am new to welding and am using MM 135 with an Argon CO2 mix. My question is how do I know when the tank needs to be refilled? Is the gas flow OK until the gages drop to zero or is there a decrease in pressure when the tank is low? Also why are there 2 gages on the regulator and what pressure range on these gages should I be looking for?Thanks
Reply:Usually the gauge closest to the tank indicates the pressure within the tank.  When I pick mine up they usually run 2,200 - 2,300 psi.  The other gauge will show you the cubic feet per hour (CFH) of the gas flow which can be adjusted with the knob/screw on the regulator.I usually run my large tank down to where the tank pressure gauge doesn't hardly show anything then get it filled.  I've got a small tank that I keep as a backup just in case I get caught short on a weekend.  Of course I might be more conservative if I wasn't just welding for myself.If you run out of gas while welding you'll notice it  TinkerCentury 135GS, ThermalArc 250GTS
Reply:Thanks for the quick reply
Reply:dprdad, I usually run at about 20-25 cfh.Bruce
GMT+8, 2025-12-20 00:31 , Processed in 0.092736 second(s), 18 queries .
