Proper way to connect welding hoses
发表于 2021-9-1 01:02:15 | 显示全部楼层 |阅读模式
This is kinda a dumb one, and I think I know the answer...Should I use teflon pipe tape when srewing in all my welding gas fittings? It seems to make sense, but I know for some things you don't want to use the stuff, so I thought I'd ask before mucking it up.Thanks
Reply:No teflon tape is needed, the seal is not made by the threads.
Reply:correct, matter of fact, some manufacturers strongly advise against using teflon tape for any hose connections.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Originally Posted by smawgmawcorrect, matter of fact, some manufacturers strongly advise against using teflon tape for any hose connections.
Reply:yea do not use tape of any kind it will have a seal with out it just make sure the threads are on good and tight
GMT+8, 2025-12-20 00:28 , Processed in 0.104237 second(s), 18 queries .
