Stainless Steel weld table??
发表于 2021-9-1 01:02:14 | 显示全部楼层 |阅读模式
Hello,First, let me say that I'm very new to welding (I've got 3 beads under my belt).  I've spent hours reading this and other forums and searching the web for answers, but just can't seem to find one for this question.I have a restaurant grade SS table and was wondering if this would be sufficient for a welding table.  For now, I don't plan on hammering or bending anything so an extra sturdy table isn't important to me.  And, I'll be working mainly aluminum, if this matters with table choice.I've picked up a Hobart Handler 180 (220V) and found a great deal on a Craftsman brand Spoolmate 3035 ($169 at sears.com) and a SGA100 ($186.30 at ContractorsSupply.com).Thanks in advance for any input,bob
Reply:They are great. That's what I use for aluminum and all the small stuff. ..
Reply:Depending on what you want to weld on the table.  How will you Dog stuff Down to Use wedges and various jigs to hold stuff in position? If Stainless Gets Hot it won't cool off very fast, So there is a Burn the Hide off your hands issue.  I imagine it's pretty thin material. Unlike 1/2" steel Plate. Personally I like to have that table for Layout and do all the Welding on 1/2 Inch to 3/4 Plate Steel.  You'll probably grind through it pretty soon.  Then there's High Reflective surface leading to more...FlashBurn!!
Reply:I have also been wondering about a good welding table material.  Mine is going to be located outside the garage, uncovered.  I simply don't have the room for it inside, and there is the issue of sparks and sawdust, as My shop is primarily a woodshop.  I'm thinking of using a catwalk type grating, as there will be lots of plasma cutting going on as well, and I want to avoid the rebounding spray of sparks.Whats a day without flippin' like a trout?
GMT+8, 2025-12-20 00:29 , Processed in 0.089806 second(s), 18 queries .
