Old Miller Welder?
发表于 2021-9-1 01:02:06 | 显示全部楼层 |阅读模式
I HAVE AN OLD MILLER WELDER/GENERATOR IT PUTS OUT TOO MUCH ON THE 110V SIDE AND NOTHING ON THE 220V ,WELDING, SIDE. MODE#CK-S/259N WITH 10HP ONAN MOTOR...ALSO NEED TO KNOW A GOOD PLACE TO GET OLD PARTS.....THANKS JERRY PS- [email protected]
Reply:I'd start by looking through the owner's manual.  You can download them from Miller's website here:http://millerwelds.com/service/ownersmanuals.php
Reply:JerryWhere in Tx are you? It will help to know where to send you.
Reply:In Austin,tx..thanks
Reply:Just up the road from me...cool.  A good place to try is in Selma,just off I-35. It is called Greer Services. Owner's name is Steve Greer. Ph# is 210/659-7101. Either Steve or Bruce can help you. They are the ones I go to for parts. They have a good stock and if they don't have it, and it is still available, they can get it.Don
Reply:SIR,there are a lot of things that can go wrong,when someone works on a machine, if theydo not have the proper information. example,a friend had a generator, that was not working.he ask if i could take a look at it. i said, can weget a wiring diagram? he had the company fax oneto him. i said, what was the last thing you did to it?he said one of the 120 outlets was burned, and hereplaced it, then it did not work. after looking at thewiring diagram, i found out why. each one of the outlets,were seperate, and all i had to do was break the littlebrass connection, between the two, and then it worked.i say, always check the simple thnigs first.wlbrown
GMT+8, 2025-12-20 00:29 , Processed in 0.069510 second(s), 18 queries .
