Basic info
发表于 2021-9-1 01:01:57 | 显示全部楼层 |阅读模式
Hello EverybodyThis is my first post so maybe you can overlook how dumb it may be. Can any of you give me some info on a Lincoln Invertec V300 tig welder?I hope I said the right model. I don't know anything about it. What is the amp range? Will it work on a 220 outlet? Is it a good one to get?I don't have much money and I need to be very careful so I don't make a mistake in the welder I choose.Thanks ahead for your help!Steve
Reply:The Lincoln website has all of the owner's manuals in PDF format.  Here is the Invertec V300-Pro: InvertecIf that is not the exact model you want, the others are also on the website:www.lincolnelectric.com
Reply:I think this welder if for arc welding?
Reply:what do you plan on doing? this machine will do-all. it's not blue but is a great machine
GMT+8, 2025-12-20 00:29 , Processed in 0.095708 second(s), 18 queries .
