does anybody know where i can find polishing products. i really need to find some tools to put the grain back into metals. (ss, alum.) thanks
Reply:I've seen all the supplies you'll need one ebay. Theres 1 or 2 store on there as well. Hope this helps.Brett B & B Fabrication and Welding Inc.Spalding, MI.
Reply:www.eastwood.com has alot of info and productsStangnetShop Full Of Stuff. Joey
Reply:thanks for the info. i will check both out. thank you again.jake
Reply:Try http://www.caswellplating.com/index.html Lots of polishing supplies and equipment.
Reply:I like to use scotchbrite belts on my belt sander- for straight grain, that works pretty well, and you can get the scotchbrite in something like 4 different grits.Klingspor sells them for every size belt sander, from teeny dynabrades up to big stationary models.http://www.klingspor.com/There is a company that makes a tool for just this purpose- it is a hand held power tool, kinda like a grinder, but with a big flap wheel mounted on it- they are pretty expensive, and unless you are doing a lot of big high paying jobs, I doubt you can justify the price, but I hear they work the best, especially for stainless.http://www.csunitec.com/sand/surfacefinishing.html
Reply:Try www.tptools.com |
