Arc welder...
发表于 2021-9-1 01:01:51 | 显示全部楼层 |阅读模式
im thinking about buying the lincoln 225 Amp arc welder Model #K1170anyway.. how would do i go about setting up the 220 volt outlet or whatever?
Reply:I own the Lincoln AC225    (AC only)  I think it's great.  I have a friend that has the AC/DC model ....  same thing, only different.I seem to be able to do anything he can. As for Electical hook up,   You'll need to pop in a 50 amp 2 pole breaker in your fuse box  and put in an outlet. If your unsure,  buy a wiring book or better yet,Call an electrician.
Reply:I own the Lincoln AC225    (AC only)  I think it's great.  I have a friend that has the AC/DC model ....  same thing, only different.I seem to be able to do anything he can. As for Electical hook up,   You'll need to pop in a 50 amp 2 pole breaker in your fuse box  and put in an outlet. If your unsure,  buy a wiring book or better yet,Call an electrician.   -JohnT.
Reply:Great machine!  I cut my teeth on one of them!  My dad taught me how to weld on his, did more learning on same machine in high school, and most shops I have worked at have had at least one that was and is still used from time to time.  I agree, 50amp double pole breaker and I believe 8-3 wire will do the trick but you may want to check that out.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Wire size, etc probably changes based on the building codes where you live, but mine is wired with 8-3 with the outlets spaced 12 ft apart on one wall.  I then have an 8-3 extension cord to take the power to anywhere in the garage or driveway.  I love the Lincoln, and it is my welder of choice for most metal projects.  It just does what you ask, 100% duty, and plenty of heat for nearly any project.
Reply:I cut my teeth on a 225/125 ac/dc.  Although the ac will technically do all the dc will do there is a safety issue with dc.   DC is better in damp conditions.  I always used DC on mine.  I loved it.  Sold it only when I no longer needed it, my new machine does everything it did plus a lot more.  Though I at times wish I still had it.  Good luckCHRIS
GMT+8, 2025-12-20 01:19 , Processed in 0.094764 second(s), 18 queries .
