rate my weld
发表于 2021-9-1 01:01:51 | 显示全部楼层 |阅读模式
Practiced vertical uphill today, about 10 welds. What do you think?lap joint on 3/8 plate. Settings were, wire speed 200 and voltage 20, not sure what the amps were. Wire .035.Ill try some overhead tomorrowops file to large, ill post pic in a bit
Reply:this is done with single pass. I tried a few with a root but the weld ended up always to convex. Attached Images
Reply:i like em there diver   keep up the nice job therechris
Reply:I can see Vertical wrote all over it....   Nice and uniform too.
GMT+8, 2025-12-20 01:19 , Processed in 0.094916 second(s), 18 queries .
