Fun quiz
发表于 2021-9-1 01:01:49 | 显示全部楼层 |阅读模式
This is a fun little test I drew up for competitions. I would like some input on how hard it is. Attached FilesVICA-test and answers[1].doc (93.0 KB, 166 views)
Reply:that's good, i like itStangnetShop Full Of Stuff. Joey
Reply:That was Fun.....  I got eight wrong, But some Question had two good answers. What do I Win?
Reply:Nothing it was just for fun. and the questions two with good answers just pick the most correct.
Reply:Being that I am a bit of a **** disturber I am taking this to work and leaving on the lunch table.....  It should be a lot of fun.  Thanks.  Number fifteen should get a good discussion going.
Reply:Come on Chase, I like some good Competition......  If I was playing for real and there was some money in it!!!!!!  I Would Win!!
Reply:I got ten wrong but formally want to protest numbers 9 and 20 .  I'm a poor loser :')))
Reply:I agree with you on 9 lol
Reply:They are all correct. You can look them up in Vol. 2 of the AWS handbook. Sorry guys.
Reply:Odd.. "You are not logged in or you do not have permission to access this page" is what I get when I try to hit that link.  Any reason why?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthOdd.. "You are not logged in or you do not have permission to access this page" is what I get when I try to hit that link.  Any reason why?
Reply:Originally Posted by WeldengineerThey are all correct. You can look them up in Vol. 2 of the AWS handbook. Sorry guys.
Reply:I agree with Lotech's arguements one hundred percent.  While the latter I am only partially familiar with, for a fact the first case of the soap vs the approved solution.  Having worked in the pipe industry I have seen this used, and also not used, depending on the applications.  In certain cases you can use soap.  Ive been able to use soap more often than not in my own personal experience.  But I also know there are applications, in my experience with med gas, where soap is not permitted.  A substance such as this would not have been created unless there was a requirenment, and there is plenty of this stuff to go around.  I found a series of what I considered errors, though perhaps less error and more that there are a number of possibilities and the wording of these questions are not necessarily quite as well applied as could have been.  Its just my opinion.  You asked our opionion.  So I gave it.  Good luck y'all.CHRIS
Reply:67% was my score. I don't consider this good but also I know very little about any process other than gas, stick or mig.that's my story and I'm firmly welded to it.btw...this is my first post....i thinkyup
GMT+8, 2025-12-20 04:38 , Processed in 0.252327 second(s), 18 queries .
