How to check weld Strength
发表于 2021-9-1 01:01:47 | 显示全部楼层 |阅读模式
I have recently welded in the top section of my crew cab , this picture does not show the welds, but I was wondering  what would be a good test to check the strength of the weld? Also what I could look for on the weld to insure its got good penetration?
Reply:are you wanting nondestructive or destructive testing?CHRIS
Reply:Since the piece is on the vehicle, which ever one would do the least amount of damage to the vehicle...
Reply:well then thats nondestruc,  however, there are no fesible tests for that.   inspection is all you can do.  send pics, top, behind, upclose, wide angle.  good luckchris
Reply:About the best you can do now is use the pieces that you either removed or have left over to replicate a little of what you've done. Then have at it, bend, pry and twist.
Reply:satex,if you take pics of it,  real good ones, I can take a look at it and give you a pretty good idea just by the appearance.  Given how thin the stuff is there arent the kinda problems you have like on a bridge or something...Chris
GMT+8, 2025-12-20 02:54 , Processed in 0.092666 second(s), 18 queries .
