Snap-On 130 MIG Problem
发表于 2021-9-1 01:01:41 | 显示全部楼层 |阅读模式
right i got hold of the above welder, second hand, i am doing a few car bonnets, welding metal eye lids on them to cause the badboy effect, most of you will know what im talking about. used the welder a few times and running excellent, but yesterday i welded the left eyelid on, then when i was doing the right one the welder doesnt seem to arc now, turns on and will work when you pull the trigger, but doesnt arc when you put on work. i have checked the earth and even opened it up to check all wires, this is really annoying me and any help would be most greatful.Ste
GMT+8, 2025-12-20 02:53 , Processed in 0.068550 second(s), 18 queries .
