Does anyone know of a site where I can learn to read welding blueprints online? As in a freebie, nada, zip, zero cost site. Surely someone has written a nice, accurate article on blueprint reading.Hmmm, if not, maybe someone from WeldingWeb should write such an article and keep it in the "Keepers" forum.Thanks all,Scott
Reply:AWS puts the welding symbol key somewhere on their site as well as Lincoln I think. The problems with print reading is that structural drawings will stump a boilermaker and pressure vessel drawings will have a structural fabricator scratching his head. It is a very big subject area. Simple foundations of orthographic projection is where to start.
Reply:Originally Posted by lotechman... Simple foundations of orthographic projection is where to start.
Reply:If you google " orthographic projection" There is quite a few hits on print reading.AWS American Welding Society has some info but is more and more restrictive...capitalism.TWI The Welding Institute in Britain is helpful.http://www.twi.co.uk/professional/index.xtp#informationLook under Job knowledge for Welders. The second section on weld symbols is quite detailed. Symbols are quite universal as are prints. I worked with a Russian who had a calculator size translator he had to use all the time. He had not problem building stuff from prints however. |
