refurbishing lincoln 225
发表于 2021-9-1 01:01:36 | 显示全部楼层 |阅读模式
Been watching awhile, learned allot, thanks for all the help! My question is, on my ac 225 code 7050-211, on the bottom of the machine is two legs, front and back. One has the axle going thru it, the other a leveling bolt i assume. I want to cut these off and rebuild them ( they're bent up and rusted bad). They are welded on from the factory. Can I reweld new ons like the originals without hurting the "block". They attach to the "heavy" part of the machine.And while I'm at it.....      Can I get one of those tig conversion deals for this machine and weld in  ac?  aluminum?  is it worth the money, can I add a tig torch straight to the machine. I have a small dc tig, but want al. capability.   Thanks for any input, and again thanks for putting all this vast knowledge on this board to begin with!!!beas
Reply:You can weld tig aluminum if you add a High Frequency unit to your machine (like a miller HF-251).  However the waveform on the older AC machines can't be adjusted as well as on a newer square wave machine.  I'd say you'd be better off trying to find a good deal on an older miller syncrowave or something similar.
Reply:About my original question, any comments?
GMT+8, 2025-12-20 02:55 , Processed in 0.092441 second(s), 18 queries .
