Welding round stock/bung to flat stock
发表于 2021-9-1 01:01:32 | 显示全部楼层 |阅读模式
I just started to tig, I have a Lincoln 185. I am having a hell of a time trying to tig round stock to flat stock. Any suggestions? Should i puddle the flat stock or the round stock at first? Should the filler rod be all the way down into the crease where the round stock meets the flat stock. I can do a butt joint pretty good and I can lay a bead pretty good but this I can not get at all. Any help would be great. ThanksMark
GMT+8, 2025-12-20 01:21 , Processed in 0.093938 second(s), 18 queries .
