ideal arc input amps
发表于 2021-9-1 01:01:30 | 显示全部楼层 |阅读模式
I am looking at a lincoln idealarc tig 300 and the tag on the back says the input amps required is 117. Am I reading the right tag ? could this be correct?thankssteveBTS Welding
Reply:Sounds a tad high but I might be wrong. There should be multiple voltages on the tag that will have different currents with each voltage.Yes I can tack it for you.    I know that won't hold but that is what you asked me to do.  Millermatic 350P XR Aluma-Pro push/pullMillermatic 185/spool gunMiller Dialarc 250 HF Water cooledThermal Dynamics Plasma
Reply:Steve ,that 117 imput could be right. I know lincolns precision tig 275 requires around 94 imput amps for maximum output.
Reply:input amps for AC for the dialarc 250 is about 90ish.  Dc is in the 70s range.Smithboy...if it ain't broke, you ain't tryin'.
GMT+8, 2025-12-20 01:21 , Processed in 0.112737 second(s), 18 queries .
