stainless to brass
发表于 2021-9-1 01:01:29 | 显示全部楼层 |阅读模式
hi ello guys ive got a bit of a teaser i need to know how you would join a stainless thin wall pipe to a brass housing havent a clue    :
Reply:Just a guess, but I would try brazing.
Reply:i know what your saying but what filler rod  just the usual copper tectic i m not sure
Reply:Plain old brazing (brass) rod. If you don't have flux on hand you can get flux coated rod. Real white coated rod. Be kinda gentle with it so you don't knock the flux off.
Reply:Originally Posted by SandyPlain old brazing (brass) rod. If you don't have flux on hand you can get flux coated rod. Real white coated rod. Be kinda gentle with it so you don't knock the flux off.
GMT+8, 2025-12-20 01:20 , Processed in 0.098974 second(s), 18 queries .
