Who can weld a backdrag blade for my plow in CT ?
发表于 2021-9-1 01:01:28 | 显示全部楼层 |阅读模式
Hi everyone. i have a 7 1/2 Fisher snowplow that I would like to have a backdrag blade installed. Anyone do this in local CT ?
Reply:Hi, I make and install a "floating" angle type of back-drag. It bolts on to the end ribs of a Fisher plow, rides up over obstacles going forward, and "digs in" when you are in reverse. $275. installed. or for an additional $50., I include a semi automatic lift system that will lift the angle when you lift your plow, (this modification is better when stacking snow, and keeps the angle higher off the ground when traveling over the road.Send me an e-mail, and I will send you some pics tomorrow. [email protected] my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Originally Posted by dannoHi everyone. i have a 7 1/2 Fisher snowplow that I would like to have a backdrag blade installed. Anyone do this in local CT ?
Reply:I`m in Stamford. Where about are you off of Merritt or 95 ?
Reply:Originally Posted by dannoI`m in Stamford. Where about are you off of Merritt or 95 ?
Reply:danno.........fully equipped...................jimwww.arctekmarine.com
GMT+8, 2025-12-20 02:59 , Processed in 0.132444 second(s), 18 queries .
