查看: 13|回复: 0
115V Welding
发表于 2021-9-1 01:01:27 | 显示全部楼层 |阅读模式
I have a 115 @ 50 amps Arc welder that someone gave me. I want to tack weld some of the motorcycle frame parts so I can make sure that they will work. I will have the whole frame TIG welded when I'm finished. Can I use this welder for that and if so what type of welding rods do I need?Thanks
Reply:Well 230volt welders go as low as 30-40 amps. Guess 50 amps puts you in a pretty narrow band of work that can be done. Get some 3/32nds 6011 if it's an AC welder, 6010 if it's can do DC.
Reply:Thanks
Reply:If that doesn't work try 1/16 rods.
GMT+8, 2025-12-20 02:57 , Processed in 0.094390 second(s), 18 queries .
