Chromoly Tubing
发表于 2021-9-1 01:01:17 | 显示全部楼层 |阅读模式
I need to weld 1/8" chromoly to 1/8" chromoly.  should this be a tig process or will a standard 60ksi wire in a mig setup work?
Reply:Tig for chromemoly...to do it right you should follow proper preheat and post heatCHRIS
Reply:it can be done with mig  I would recomend a er-70 series wire and a mapp tourch for pre and post heating.....tig has more heat control though..look it up on lincolns site....Bonez
GMT+8, 2025-12-20 01:25 , Processed in 0.091163 second(s), 18 queries .
