Trailblazer 302 with problem
发表于 2021-9-1 01:01:15 | 显示全部楼层 |阅读模式
Hello,    I hope someone can help me.  My new Trailblazer (not even 100hrs yet) has developed a rather curious problem.  When I'm using stick the machine will rev up at random for apparently no reason.  The display shows very low amperage is being created (between 7-11amps)  There are no shorts in the cables.  The problem is inconsistent and seems to be happening more often.  Anyone have any idea what's wrong?
Reply:dendog, not sure if this can help you or not, but I ran into a problem similar to what you described, and it was the idle solenoid box was malfunctioning.  Now this was on my bobcat, but as soon as i replaced it I had no more problems.  Personally if it was me,  I would call who you purchased it from and have them check it since I am asuming it is under warranty.  Good luck, let us know what you find.  ~JacksonI'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
GMT+8, 2025-12-20 01:32 , Processed in 0.094520 second(s), 18 queries .
