sautering copper to brass
发表于 2021-9-1 01:01:09 | 显示全部楼层 |阅读模式
ok... here is the question.... what material do you use to fill in when sautering together copper to brass? Is it silver sauter? Brazing Rod? Etc. Hopefully I asked the question right?Thanks for any inputLast edited by mindyc7777; 12-01-2005 at 01:57 PM.
Reply:Just thought you should know, the word you're looking for is solder.For common copper and brass pipe fittings, you can simply use the lead-free solder and flux available at any hardware store, with a propane torch.  If you are building something more high-tech, many brazing alloys could be suitable.Looked up sauter in Merriam Webster online dictionary ( http://merriamwebster.com/dictionary/sauter ) and came up with this.Main Entry: re·cu·ler pour mieux sau·ter Pronunciation: r&-k[UE]-lA-pür-my[OE]-sO-tAUsage: foreign termEtymology: French: to draw back in order to make a better jump
Reply:Go to youur local welding supply house like AIRGAS and get the right stuff
GMT+8, 2025-12-20 01:53 , Processed in 0.069214 second(s), 18 queries .
