water cooled idealarc 300/300
发表于 2021-9-1 01:01:01 | 显示全部楼层 |阅读模式
Does anyone know how I can hook up my water cooling system for the Lincoln ideal arc. I bought this used and need to get it hooked up. Any help will be greatly appreciated:
Reply:I'm guessing that you are asking about a "power cable adapter".The power cable adapter is essentially a brass fitting that transfers power from the welder, and water from the chiller, to the power cable of the water cooled TIG torch.  Western Enterprises makes these, and every other welding related brass fitting, cylinder adapter, etc. ( http://www.westernenterprises.com/en.../PDFS/wi16.pdf ), see bottom of page 33.If this is what you are looking for, or if it's something different you need to make your system work, I suggest you talk to Jim at Arc-Zone, ( http://www.arc-zone.com ).  He has been very helpful, easy to deal with, great service.Tell him Stan from Santa Fe sent you.
GMT+8, 2025-12-20 01:34 , Processed in 0.073384 second(s), 18 queries .
