Cold weather welding question
发表于 2021-9-1 01:00:57 | 显示全部楼层 |阅读模式
HI,I need to do some welding on my car trailer and I'm wondering if I need to do anything special for winter temps. I have a Lincoln 135 wire feed rig and will be welding 3/16 mild steel, temps here is around 40 degrees. thanks
Reply:heat the steel first till it's at least worm to the tuch and it should be clean to chuck
Reply:Thanks, I used a propane torch to wamr the steel and surrounding areas and it turned out fine.
Reply:Rock, the general rule of thumb Ive always been told and lived by is 70degrees.  Ive definately welded stuff less than that.  BUt on strcutural applications thatr require no preheat I do beleive they do require min 70 deg.  Its beena  rule of thumb ive stood by.  obviously as you said it turned out fine and thats good.IF it Catches...Let it Burn
GMT+8, 2025-12-20 01:32 , Processed in 0.092932 second(s), 18 queries .
