Technique for bending anle iron?
发表于 2021-9-1 01:00:48 | 显示全部楼层 |阅读模式
I need to radius a piece of 2x2x1/4" angle. It's for a snow plow, one side of the angle rides under a piece of flat as it rotates side to side.  I have a Hydraulic tubing bender (the Northern tool variety) will this do it or is there a better way?  TB
Reply:well this probably isnt the best way .but i have made arched window frames out of 1 1/2" angle by cutting pie shapes out of one side and then cold beating the other side of the angle on an anvil or some other round shape and then welding it all back up. I only had to make two, so even though its not the best way it worked. very cheaply. sorry about the picture you cant really see the frame . the only pic i have is after installed Attached ImagesBTS Welding
GMT+8, 2025-12-20 01:32 , Processed in 0.123396 second(s), 18 queries .
