"Another One Bites the Dust" (A MUST READ)
发表于 2021-9-1 01:00:43 | 显示全部楼层 |阅读模式
http://www.anvilfire.com/iForge/tutor/safety3/index.htm
Reply:my bad. I should have looked first.  I see now this is already posted.  Unforutunately; apparently I can't delete this one.  I tried.
Reply:Things like this need to be posted often, so folks will see the effects of "little" mistakes.Smithboy...if it ain't broke, you ain't tryin'.
Reply:Worth reading. I knew a little, now I know more. My dad use to say " weld gal outside and keep your head out of the smoke."
GMT+8, 2025-12-20 01:32 , Processed in 0.067378 second(s), 18 queries .
