oa tank question
发表于 2021-9-1 01:00:31 | 显示全部楼层 |阅读模式
i recently purchased a oa tank setup .the guy i bought it from had a home made tank cart were the tanks sat tandum instead of side by side . my question is . is it a safe setup for them to be like this or is it safer side by side ?It's good enough for the girls i run with
Reply:every cylinder "truck" we have is side by side..one in front of another is really not a good idea..they can tip over much easier than side by side ...zap!
Reply:Change your perspective.  They are in front of each other even when they are side by side.
Reply:Like standles says, two tanks are always side-by-side.  I could see a tiny weight and leverage issue that way. One tank further out front might be harder to raise up or handle on bumpy terrain. Other than that the tanks don't care.
Reply:Originally Posted by standlesChange your perspective.  They are in front of each other even when they are side by side.
GMT+8, 2025-12-20 01:53 , Processed in 0.092469 second(s), 18 queries .
