Miller vs Lincoln inverter tig
发表于 2021-9-1 01:00:30 | 显示全部楼层 |阅读模式
Anybody out there have an opinion as to which one of these is the best?
Reply:well i my self prefeer lincoln's over miller and i have used both and still doright now my favorit is the V160T that is one small machine that was made to weld at work i use a miller econo tig and im not impressedChuckASME Pressure Vessel welder
Reply:The econotig is not an inverter so that's not a fair comparison.  As to Lincoln verses Miller it boils down to personel preference most of the time.  There will be a difference in the arc between the two but they will both do the job.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-20 01:50 , Processed in 0.068748 second(s), 18 queries .
