flux core or spray transfer
发表于 2021-9-1 01:00:26 | 显示全部楼层 |阅读模式
whats up? i am welding 11/2"base plates on w10*50 i beams print calls for 5/16 weld i find that .045 wire gives me alot of undercut with one pass would like to switch to 1/16flux core any suggestions?
Reply:if your getting under cut with spray than your doing some thing wrongChuckASME Pressure Vessel welder
Reply:Try dropping the volts
GMT+8, 2025-12-20 02:53 , Processed in 0.092181 second(s), 18 queries .
