Yet Another Post
发表于 2021-9-1 01:00:23 | 显示全部楼层 |阅读模式
Sorry for being a pain in the arse with the posts, but i guess thats what a forum is for.Ok, what i was just wanting to clarify, is the flux on a stick/electrode for stick welding.Does the flux on the stick provide the gas that stops oxidation of the molten puddle, a bit like the gas that comes out of the GMAW, instead of using gas out of a bottle, it comes off the stick? is that correct? And does it also provide the slag which protects the weld also? And i was just wondering what the flux is actually made of, cause i have been doing a ****load of research on Oxyacetylene and what its made of (CaC2 + 2H20 > Ca(OH)2 + C2H2 and that it burns a NEUTRAL flame at 5600 - 6300 deg Far. (3093 - 3482 Cel.)Also, can someone please check this for me, i have been doing a lot of notes in a booklet that i have to provide to my trainer every 2 weeks, and i just want to see if this table is correct.Metal Melting PointsMetalMelt Point(F)Melt Point(C)Aluminuim1217658Brass1652-1724900-940Bronze1566-1832852-1000Chromium30341667Copper19811082Gold19461063Iron27861530Lead621327Mild Steel2462-27861350-1530Titanium32631795Tungsten54323000Zinc786418I have to show my trainer soem notes every 2 or so weeks when he comes out, so i just want to make sure everything is right, and make a good 1st impression on my new trainer, so please feel free to constructivly criticise my work. Here is some more:Welding ProcessesMetalWelding ProcessCutting ProcessMild SteelAll Welding ProcessesOxyFuel, PlasmaAluminiumGTAW, GMAWOxyFuel, PlasmaStainless SteelGTAW, GMAW, SMAWOxyFuel, PlasmaChrome Moly SteelGTAW, OXYFUELOxyFuel, PlasmaTitaniumGTAWOxyFuel, PlasmaCast IronSMAW, BRAZINGOxyFuel, PlasmaBrassBRAZE WELDINGOxyFuel, PlasmaPlease tell me if they are wrong, as i am memorizing these as i go, so i dont want to be learning the wrong ****.I came across this little equation and i thought it might be useful, here it isCalculating heat input for arc welding:Q =(V x I x 60) Efficiancy      ---------      3 x 1000Q= Heat inputV= VoltageI= CurrentS= Welding Speed (mm/Min)Is this correct, if not, what is, and can it be used?Please let me know of any flaws in this text, and i will fix them in my book, cheers people."One World...One Muay Thai...Muay Thai Never Dies..."
GMT+8, 2025-12-20 02:53 , Processed in 0.094570 second(s), 18 queries .
