Small torch set?
发表于 2021-9-1 01:00:22 | 显示全部楼层 |阅读模式
Anybody know how long one of these little torch sets with a 20cf ox bottle and 10cf acetylene bottle will last or cut?
Reply:With a 00 cutting tip, at 20-25 psi oxy, and 5 psi acy, at the recommended 35 scfh oxy, and 6 scfh acy. .......... The oxygen should last around 40 mins, and the acy, around 90 mins.Thats my guess........... anyone care to check my math?Remember that you shouldn't draw more than 1/7 the volume per hour, from the acy. bottle.......that would be about 1.5 cf per hour.Here's a good tip chart with the flow rate and psi recomendations.http://www.hoopersupply.com/tipchart.htmlLast edited by BBchevy396; 04-01-2006 at 08:30 PM.We need to protect Freedom of Speech, otherwise, how would we know who the A-holes (like me) are.
Reply:sounds good to me JimIF it Catches...Let it Burn
GMT+8, 2025-12-20 02:52 , Processed in 0.103683 second(s), 18 queries .
