wire continues to run after releasing trigger
发表于 2021-9-1 01:00:16 | 显示全部楼层 |阅读模式
I'm setting up a new Esab multimaster 260. Welds great.  Problem...after releasing the trigger the wire continues to run for about 27".  What should I check or adjust to correct this?  Any help would br greatly appreciated.Thanks, JRF
Reply:Sounds like the trigger may be sticking. You can check that with an ohm meter.  I would call ESAB and talk with them.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Might be a tiny slag ball in the trigger. If you're a take it apart put it back together type person its an easy fix.
Reply:Trigger
GMT+8, 2025-12-20 02:54 , Processed in 0.073494 second(s), 18 queries .
