查看: 13|回复: 0
windflag , high amp tig
发表于 2021-9-1 01:00:15 | 显示全部楼层 |阅读模式
High amp tig creates a lot of heat in the torch. So much in fact you wonder if your water cooler is running. If your welders fan runs all the time, or there is other background noise, you may not be able to hear the water cooler run. Tie a short piece of ribbon or string to the cooler where the air comes out. You will be able to tell at a glance if the cooler is running.
GMT+8, 2025-12-20 02:52 , Processed in 0.094380 second(s), 18 queries .
