AR 400 steel
发表于 2021-9-1 01:00:14 | 显示全部楼层 |阅读模式
What rod would you use for welding ar400 to structural?
Reply:Ive used 6010 on AR500 to structural...worked fine. I would think 7018 would equally work.  Whats your purpose?IF it Catches...Let it Burn
Reply:Use preheat, and cool slowly............We need to protect Freedom of Speech, otherwise, how would we know who the A-holes (like me) are.
Reply:Building a root rake for a dozer.  Want to weld one inch ar400 teeth to a half inch thich 4X4 angle.  Once that is done I'll weld a series of half inch plate gussets.
Reply:Definately follow Jims advice...Infact...hmmm...My experience with the 500 was much thinner....Jim knows better than me on this stuff....He will gladly give you more info IF it Catches...Let it Burn
Reply:Another question. How does ar400 cut with a plasma cutter?
GMT+8, 2025-12-20 02:52 , Processed in 0.097376 second(s), 18 queries .
