wire size question
发表于 2021-9-1 01:00:13 | 显示全部楼层 |阅读模式
this welder i got came with 0.8mm wire flux core now whats a good sized wire for auto body should i stick with 0.8mm or go with a different sizeLast edited by chevelle; 04-05-2006 at 06:59 PM.
Reply:Originally Posted by chevellethis welder i got came with 0.8mm wire flux core now whats a good sized wire for auto body should i stick with 0.8mm or go with a different size
Reply:Body work, .025", ER70S-6, w/ Ar 75%/CO2 25% mix gas.
Reply:I tend to agree with mjedude you really want to MIG body work with gas and wire.   Flux core isn't MIG and confusing the two doesn't really help.All that being said if you go flux core you neeed to run the smallest wire you can find and will run through your welder.   The problem with flux core is penetration, to much of it in fact with larger wire.ThanksDave
Reply:How do you plan to neutralize the flux?If you plan to paint over your welds, they will likely have adhering issues due to the above.Use .025 wire and c25.
Reply:Originally Posted by crackedbackHow do you plan to neutralize the flux?If you plan to paint over your welds, they will likely have adhering issues due to the above.
Reply:ive heard these claims, but like mac I believe its falseIF it Catches...Let it Burn
GMT+8, 2025-12-20 02:54 , Processed in 0.093947 second(s), 18 queries .
